Disables ELRP packet transmission on ports of an ESRP domain.
esrpDomain | Specifies an ESRP domain name. |
ports | Specifies list of slots and ports in the ESRP domain. |
all | Specifies all ports in the ESRP domain. |
All ports of an ESRP domain have ELRP transmission enabled.
If you have host ports on an ESRP domain, you do not need to send ELRP packets to those ports.
If you change your network configuration, and a port no longer connects to a master, slave, or ESRP-aware switch, you can disable ELRP transmission on that port.
The following command disables ELRP packet transmission for slot 2, ports 3-5 on ESRP domain esrp1:
configure vlan esrp1 delete elrp-poll ports 2:3-2:5
This command was first available in ExtremeXOS 11.1.
